Re: Lower Unit attachement
J.kpec<br />Thanks for the tips...I can get it in forward using the shaft, for instance when if I were to put pliers on the little arm and turn it with or without the lower unit attached it will go into gear. However, when I use the shifter at the helm it is tight and hard to move, and when it does move it takes the unit out of forward and into neutral. If I move the shifter at the helm to forward or reverse from the helm after this it will stay in neutral. It seems as though it doesn't take alot to back it out of gear. I noticed when I was installing the unit, one of many times today the slightest movement from the shaft would put it in neutral. Not sure if this is from my first mistake or I am still doing something wrong. Anyway guys I screwed it up, I am blaming this on the seloc book of course for not cleary describing the damn little arm thing. I am to good to make a mistake on my own LOL.
