Ok, I have a 1973 Starcraft SS deep v-hull aluminum boat 16' and over the winter I plan on making some new cushions for the bow. I pulled the old ones which are moldy and the vinyl is bad. I am going to use the old ones as my template to cut new wood and put some foam and marine grade vinyl. When I replace the floor in the spring, I am going to use marine grade plywood, but do I need to use that wood for the seat cushions or can I just use regular plywood? If I use regular plywood, should this be sealed with epoxy or something? Any suggestions on supplies for the cushions? I found an online source for fabric and they have marine vinyl for about thirteen dollars a yard and I would need four yards. What about the foam? Should this be outdoor foam, like one might use for outdoor furniture. There is a foam product that does not absorb water but would cost about eighty bucks to do all three cushions. Has anyone ever made new cushions?
