Appreciate any help with the following problem. I have a 2005 Mercury 175 Optimax and have had a starting problem on two different occasions. After fishing all day and the motor starting a dozen or more times I turned the key and nothing to the starter.The alarm bell beeped and you could hear the first relay make noise but nothing after that. I checked the fuses at the motor all were good. After we pulled the boat to the dock we let it sit for about a 1/2 hr and it fired up fine and i shut it off and restarted it 5 or 6 times no problem. Took the boat home and hooked up water could not get it to duplicate it started fine. Next time out similar situation boat started fine all day after numerous starts again bell sounded relay made noise and no juice to starter.The other relays did not make noise.After an hour or so Boat started and continued to start which I did 5 or 6 times.Problem is intermittent so hard to diagnose. Any help is appreciated.
