Re: Gel Coat is tacky.
ok bud......
we have to go back to some basics here.......you are missing lots of info.....i dont mean to speak for ondarvr....but i know he does not have time to type the whole process out.
ondarvr is a factory rep ....most likely for the gellcoat that you are using. so do what he says.
ok......
1. air inhibits (stops/slows/screws up) the cure of poly based resins.
if you use gellcoat with wax in it.....it will come to the surface in the first few minits of the cure.
2. wax is a release agent......that means poly based resins will not stick to it.....if you shoot gell over a wax cured area....the new layer will not bond.
3. this means that you shoot all in one shot......all of it.....no first or second coat. (do not spray a coat....let cure...then spray a second coat like you do with paint.)
you can walk around the boat a few times....shooting as you go....but you must get back to the starting point before the first layer starts to go...because the wax will start to come to the surface.
if shooting smaller parts/areas....it is done all at once.
4. wax is called airdry. and sold separately....it can be purchased in the product (aka waxed resin or waxed gellcoat. but once the wax is in the product, there is no way to get it out, so you have a product that can only be used as a final layer product). if you purchase un waxed.....and add you own wax. you can use it when ever you want.... and just add the wax in the final layer.
5. gellcoat must not be too thick or too thin when applied.......it must be applied at a final depth of 35 thou. you can get a mill gauge from any paint store.
you can shoot at 50 thou,,,,and sand down (knock off the orange peel) to 35 thou.
6. there are two methods for wax......on the east coast.....the common practice is to shoot un waxed.....then after the shoot....spray with pva.....(this must be done out of a gun, and not a plant mister. the mister will clog instantly and you are hooped.
the pva can be washed off after the cure with soap and water....
the reason for this, is because when you start to sand......sanding with wax, paper loading is an issue till you break thru the wax,,,,then it is not as extreme.
small areas are not as bad.....but large areas like a full hull....it is costly and a real headache.
on the west coast....we shoot wax in.. at 3%....
use one or the other (pva ro wax).....not both.....you are working against your self.
you can shoot the part with unwaxed gell......and on the final walk around, add wax to the gell.... just make sure your coverage is good. or it will be blotchy.
7. when shooting a project........you have to have a plan.....you are shooting really really thick.....so sagging is a real issue. that is why a walk around is common....giving the gellcoat a little time to start to set up before the next layer goes on.....(but nowhere near a cure)
8. cat rates.......1.5-2.5% OF THE GELLCOAT....no more....no less.......a really hot batch is 2.5%.....this gives you very short time in the pressure pot......you have to shoot the whole pot in under 10 minits or the gellcoat will start to go off in the gun, the lines, the pot......and you are hooped.
I shoot at 2%. this gives me 15 minits from mix to empty pot.....
9. mixing. thinning, adding of products to gellcoat.
mixing must be done thoroughly......when you think its mixed ...its not......you can add a pigment to gell coat......mix with a stick for 5 minits......and still see a full strand of pigment come to the surface after 5 minits of vigorous mixing in a small cup or pail.
i use a egg beater on a drill....you want a vortex to srart....and keep that vortex going for a full 3-5 minits depending on the size of the mixing container.
9 a. adding thinners like acetone or patchaid......NO MORE than 10 %...wax is added to a maximum of 5 %....i use 3%
gellcoat is very very thick........the tendency is to add thinner till it shoots nicely like paint.....gellcoat is not paint....adding other chemicals distorts the molecular chain as the gellcoat starts to cure......this will give you a weaker final product, and cracking or crazing will be an issue in a few years.
most gellcoaters don't get to see there work after 5 years....so they don't see what happens to the product over time. they might thin at 30%......the product goes on well, and cures hard....so they think it worked.....but after a few years...it will fail...but they never get to see it as the boat has most likely been sold, or the owner has moved on.
sticking to the manufacturers instructions is the only way to maintain it integrity of the product.
these are some basics......you really need to grasp these concepts.....so your shoot goes well.
i did not get into the gun or pressure pot system at all. but if you pull a search....there are several threads on the subject.
cheers
oops
