Beefer
- Aug 4, 2008
- 1,737
Ever since I've owned the boat, the floor panel over the fuel cell has been soft. You could see at the pie plates where the plywood was rotting, and when I first got the boat, I laid down some aluminum angles as added support. It worked well enough for what I needed at the time.
Fast forward to today, where after a morning of tubing, I decided it was time to actually do the floor repair. I pulled the panel, and started trimming away at the bottom glass to seperate it from the top, expecting to see a big piece of rotted plywood. Instead, this is what I saw:
A bunch of 6" square pieces of 1/2" (or 3/8") of plywood semi-resined in. No wonder the dang thing rotted. There are areas where there was no resin between the pieces, and there were only 4 pieces that weren't rotted all the way through.
For those of you who would know, is this common? To me it looks like a cheap shortcut; use the scraps from around the shop to build the floor.
I'm planning on replacing the wood with nidacore, or some other lightweight substrate. Any suggestions?
