ricardo100
- Nov 11, 2011
- 9
Howdy. I have a 1988 Mariner 150, it's had a charging problem which is fixed now. It's also had an oil alarm issue which I am trying to work through. The marine shop tested the alarm systems while it was there but said they were all ok. The alarm only beeps intermittently after about 15 mins of running, then becomes a continuous beep beep beep after about 20mins. Then will still beep when the key is turned on whether the engine is running or not.
Top oil tank is completely full and I have tried another top oil tank cap/sensor but still the same result. Plenty of oil getting to the engine also. Any other thoughts? Any suggestions on ways to test the oil pump pressure sensor as the Marine shop is sending me broke.
Also, the new rectifier/s installed have stopped the rev gauge going over 4000rpm, :facepalm: But when I hit the trim switch, it reads correctly for about a second? Help!
Many thanks. Rich.
Many thanks. Rich.
