If anyone can help me diagnose my problem I would be grateful.
I have had the outboard since new and had very few problems.
Towards the end of last season I noticed that when we were underway the tacho needle would drop to zero and then flick back up to the correct rpm (intermittently). It has gone through several different stages (see below) and now will only register idle speed and when the engine is accellerated drops to zero. when I return the throttle to idle it reads idle speed.
Other things I have noticed since the problem started:
1. Tacho needle drops to zero and then returns to the correct speed.
2. When I start the motor at sea the tacho would read idle speed and then as I accellerated the motor it would drop to zero and then some time later it would show the correct rpm (could be 1 minute or 5 minutes very irregular).
3. When we are underway and the tacho is reading say 4000 rpm and you trim the motor the tacho needle drops down to zero then returns to the correct speed when you stop using the trim switch.
4. Now it will only register idle speed and as soon as the engine is accellerated it drops to zero and stays there until you return the throttle to idle.
Thanks for any help.
