My dad's mid '70's vintage mercruiser with the 4 cyl GM engine has a bad "dead spot" sputter as you accelerate off idle. If push the throttle slow, it gets past it OK, but if push it quick, the bobble is pretty bad, it may or may not backfire, and occassionallly stalls.<br /><br />Some history... he was having problems with the rough idle that he thought was ignition related, so he bought new plugs, wires, distributor cap, rotor, points & condenser. He had put all this stuff in and I arrive to look over his shoulder just as he's putting it back together. He's careful to put the wires on the distributor just like they came off, but I comment that it can't be right... who's ever heard of a 1-2-3-4 firing order?? He's adamant that's how they were, I check manual, it says 1-3-2-4... look on block it also says 1-3-2-4 so that's how we put it together. Fired it up on the muffs, adjusted timing to 8 deg's as per spec, and adjusted idle mixture screws ~ 1 3/4 turns out to get us close until final tune on the water. Seemed to be nice smooth idle. On water, it runs good except for above mentioned dead spot. Adjusted idle mixture screws, which seemed to have only a minimal effect on the deadspot...deadspot might be marginally worse when the idle is smoothest. (?) I thought maybe choke was partially engaged, so I turned cap on choke about 1/8 turn to "lean"... no effect.<br /><br />I didn't say that once past this spot, the engine runs better than I ever remember it running. I've got to check it against my boat, but I'm sure he's gained 5+ mph. Amazing how firing the plugs in the right order smooths things out!! If it was wrong for quite a while, it's amazing to me that it ran as well as it did.<br /><br />Seems like a mixture problem to me... air leak, or choke issue or ???? What do you think?<br /><br />Thanks for your input...<br /><br />Brent
