artificialreef
- Feb 21, 2009
- 504
Good morning folks. I am working out my electrical gremlins. I fixed my no spark issue. I still have an intermittent wont turn over situation. What i have noticed is when i turn the key, the only gauge that moves is the power trim gauge. I have read that the sending units on the drive go bad quite often. Which course of action should i take next. I am thinking of bypassing the gauge or disconnecting the sending units or maybe trying to adjust first. The needle on the gauge gets pegged when i turn the key to on. Like i said no other gauges come on. Disableing is only for testing. I will replace the defective unit once it is identified. The battery is strong, because when it does turn over it turns normal. All the connections have been cleaned and tightened.This is on a 1983 470 with an R drive.
Thank you for your assistance.
