Re: alpha 1 gear ratio help?
not to hijack the thread, because I think this would also help the OP.
but what is the difference between all the gear ratio's, I have had people tell me it doesnt matter.
I know from what little reasearch , all the drives use the same shaft that ties into the motor.
and that there is maybe 1 or 2 gears inside that are the main difference.
Is there a "all you ever wanted to know post"
As far as the drive itself goes, yes the only difference is the 2 gears inside the top box. All the shafts, bearings, seals and housings are the same.
As for performance there is a HUGE difference. The gear ratios are selected so as to have the engine's torque curve utilised to the best possible effect. That means working out what sort of size boat that engine is typically going to be installed in, what the maximum and cruising speeds are likely to be, and then getting the ratio so the 'right prop' is in the range that is manufactured. eg, you could have a V8 with a 2.3 ratio leg, but you'd need a prop of around 29" pitch mark... and that's not too practical. Alternatively you could put a 1.32 ratio behind a 3 litre engine, but try finding an 11" prop for it!!!
When you look at the ratios you see that as the engines get more powerful the ratio decreases...
3 litre (140hp)- 1.94:1
The old 470 (170hp) - 1.84:1
4.3 litre (175 to 220) - 1.62:1 (some older models were delivered with 1.84:1 drives)
V8s (200hp to 300hp) - 1.47:1
Chris..........
