200hpdi ox66
joepatch
where is o2sensor located? Also when ignition is switched alarm sounds and keeps on even if I start engine. Thanks for any help
Re: 200hpdi ox66
It is on the stbd side of the motor, has 2 white wires going to it. Why do you ask? Usually when the safety lanyard is pulled the alarm will sound but the engine should not start though. If the engine starts could be low oil in the tank or the overheat alarm grounded against the block (pink wire).
