I'm talking spar or epoxy varnish. Do you guys spray, roll, foam brush, or use a high quality bristle brush?
What is the application ?
Wood is kinda .. General .. ..
I would ask again with some pics and expectations of what you want from your ..Finish ..
YD.
PS. Woody and BWT might be a good source to begin with..
The application is a transom and a seat bench...both exposed to sunlight.
What wood are you talking about ??
Mohog or Teak ? .. or Custom build wood ?
YD.[/tQUOTE]
Nope....just ext. plywood....basic tinny rebuild....but my dash is solid mahagony, was gonna use marine spar varnish on that and a combo of epoxy and spar varnish for the plywood (epoxy base coat with 4 coats spar varnish over it)
