Let's hope the boat was in the water and on plane when he did this read out test???Welcome to iBoats.
You rev'ed it too high in neutral? Anyway, someone with experience in these read-outs will have some meaningful input. Welcome.
Welcome to iBoats.
I am not familiar with the diag read-outs, but it must be that Lake Temp! or the fact that it hasn't been over 4K rpms yet. You rev'ed it too high in neutral? Anyway, someone with experience in these read-outs will have some meaningful input. Welcome.
Looks like you need to check or adjust the gear position switch on the shift bracket.
To answer that I need a serial number.
At this point we don?t know if you have alpha, bravo or an inboard.
Posting a serial number makes it much easier for a mechanic to pull up parts and service manual info.
http://forums.iboats.com/showthread.php?t=220416
