low presure light is on 6hp 2009 four stroke Yamaha
freedom49
when start up my 6hp yamaha the LOW PRESURE light comes on I check the D stick is full ,help please?;)
99yam40
Re: low presure light is on 6hp 2009 four stroke Yamaha
Could be low pressure or a bad sensor, need to check pressure to see
freedom49
thanks will check these.do you know how to check the oil pressure ?
99yam40
I have never even seen a 4 stroke 6 before but I am sure a service manual would give you info .
I would think pulling the sensor and testing it would be the 1st thing and then hooking a pressure gauge to the port you removed the sensor from would be the next thing, but if it really is low pressure the you might hurt the motor by running it
freedom49
red light is on when motor(2009- 6 hp four strok running)
when start the motor red light stays on!Can it be from me lay the motor down on its sids and lots of oil draind?
freedom49
thanks for your help.
