bigboat606
- Sep 6, 2009
- 52
I have a VRO pump on my 1987 200 HP Evinrude which is not pumping fuel. I placed a clear hose on the output and saw no fuel flowing. I also measured the output pressure. It was very low 'bouncing' around zero with each vacuum pulse. The pump is a BRP P/N 5007422 which is a pre-mix pump (no oil chamber - so I guess it is technically not a VRO) which I installed last year. It only has 30 hours on it. With such low use on the pump I'm having trouble believing the pump is truly bad. Is it possible I'm missing something...like the vacuum drive? I measured the vacuum line with the engine idling and it showed a VERY RAPID reading from 0 to 5 inches of mercury. This was measured after the pulse limiter at the input to the pump. My OMC manual only mentions the pump output pressure spec to be 3 psi, but does not discuss the vacuum pressures. I would like to fully check-out the pump before I buy a new one for $350 or so. I also pulled a hard vacuum on the pump vacuum outlet. It held with no leaks. Can anyone give me information on how to check out the pump? Likewise is there anything in the vacuum circuit I'm missing and can check?
