Re: Old trailer new car- need help wiring
the easiest way is to drop by one of several places that sells trailer wiring supply's and pick up a wiring harness T connector, it is designed to be put in the existing vehicle harness, on all vehicles their is a connection point from the main harness back to the rear lights it is normally on the frame some place close the back of the car or truck you may have to trace the harness back from the back lights to find it. That's the hardest part. The T connectors are designed to snap in to the factory harness, and have a 4 wire outlet to match up to most trailer harnesses. To do the job you need the T connector and a 4 wire drop cord that has booth normal trailer wire connectors on it and some dielectric grease and a few wire ties. their is no cutting or sorting what wires dose what. Every thing is converted and hooked up correctly in the T connector. I normally get mine from Advance auto, but I am sure their many other sources.
