southernboater
- Aug 26, 2009
- 38
I have a Lowrance M56 finder which is probably 5 - 6 years old. The casing around the connector pins (cable end) has become brittle and cracked in some places. There is also some corrosion on the female end of the connector (cable end). The result is a poor connection which you have to play with until you get the correct position and hope it works. Is it best to replace the entire cable or can the end be replaced? If I replace the cable, do I also replace the transducer?
Thanks for any advice.
Southernboater
06 Manitou Osprey
Southernboater
06 Manitou Osprey
