I had couple of questions and maybe you guru's out there can assist with my issue. I have an Mecruiser 5.0L Carb, Serial # 0W311065. I've replaced spark plug, fuel/water separator. Boat been sitting since Dec of 2010. Ran the motor on muffs this pass weekend and the motor started up idle perfect, I let it run for about 20 minutes on the muff and motor sounded good. Took it out the next day on the water, started it up fine, left the dock doing about 40mph and the then motor splutter and shutsoff. Tried to restart it but wont start. Waited couple of minutes and would still not start. So i pushed in the lever and gave it some gas and it would start but when i put it back into neutral motor shutsoff. So i took off the Flame Arrestor and adjust the idle screw. My buddy push the lever forward and i can see fuel squirting into the carb. Place the lever back started the motor up in neutral and the motor stays on. Left the motor running about 5min idle was a bit high but didnt want to lower just incase it would shutoff again. Need to get back to the docks so i put the motor in gear and it didnt shutoff, when i accelerated i can hear backfire and splutter like the motor was going to die, so i dropped the lever to lower the speed to get me going atleast. I couldnt go wot or the motor would splutter and shutoff. I'm guessing and reading the the forums here, leaning toward bad fuel or dirty carb. I've bought some Seafoam and going to pour some into the fuel tank let it run and then clean out the carb with seafoam/carb cleaner. Any ideas would be greatly aprreciated.
Thanks
Thanks
