I am finished cutting all the Stringers, frames & keel of the plan below. The parts weigh about 100 pounds. Engine is a inboard 305 CI Chevy with dry exhausts for raceboat get togethers. No mufflers needed.
Sooo. How thin can the 3 to 4" wide planks be if NOT using Mahogny ? How about Sitka Spruce or other similar weight & strength.
The version I am doing only has the rear seat open. Fronts are decked over. Engine in about the same place. We will slide the engine around to get level.
I know very little on very light race boats planking woods. I will be gluing the planks edges with those " Biscuts " for rigidty.
Thanks
Thanks
