Just istalled a brand new Minn-Kota terrova and connected my 2008 Humminbird 747c with M-K adapter cable. Easy installation and what a fantastic TM. But the bow sonar is picking up motor noise. Sonar is on engine battery and TM is on separate TM power system, 24 vdc, but the wires do come out of the same boat cable pipe. M-K tech support said I probably need to reroute the cables on separate sides of boat. Probably right but not exteremly practical and may not work anyway. When asked if they had a filter they said Humminbird had a filter and they do (called a choke) but it costs over $90.
Its on a Lowe 175FM 2008 model. Thought it would be good idea to get a wiring diagram and see if the low amperage sonar cable could be replaced with shielded wire instead of the high current TM wire. Anyone know where I can get one? By the way my Motor Guide W55 did not make noise on the sonar but the transducer was on the transom. The console sonar, a Lorance HDS5 did not pick up any noise but may have better rejection capability.
Anyone think shielded wire might help or have an idea on a low cost radio shack type filter ie a capacitor and/or diode acroos the line?
Thanks for any ideas.
