When replacing a cracked 4.3L mercruiser block (gm casting 867) that was produce late 80's early 90's, can I use a newer 4.3L Vortec short block ? Will my heads (768) and intake fit the newer block? Will my flywheel bolts on ? Does it make a difference that the newer block is set up with a balance shaft? The only visual difference I can see is that I will need to add an electric fuel pump as the newer block is not set up for a mechanical fuel pump. This option is being explored as it is hard to find an older short block with low hours and my heads and manifolds are in good shape. Any input would be helpful.
