My motor is by the emission control sicker a 1999 2 stroke mercury 37-856984-7 Also says its family is XM9XM0059210 and then says 40-60hp on it. Its mounted on a 1999 smokercraft spitfire 162 boat. I have found a used pump but all that owner can give me is its a 810 outboard jet and says its for a 60hp merc. So my question is how can I tell if this will fit and if it will fit do I need anything else with it like a diffrent water pump, jacking plate etc? Also found this number as a serial number but not sure I'm reading it correctly as I can't match it to anything so if u can help with this for future parts issue that would be great to. I think it says 0G818627 and its a 1999 60elpto motor thats from a little sticker on the transom motor bracket and its about the best I can make it out.
Thanks Alan
Thanks Alan
