stevebollinger
- Mar 24, 2010
- 2
Hi, on the above mentioned motor the system check goes as planned (lights go on and then back off), but when the key is left in the run position or the motor is started the water temp light stays on with alarm. I've disconnected temp sensor and no change. I believe there may be a shorted wire to ground some where. Do I just need to trace just the tan wire? From looking at the wiring diagrams it appears the tan wire goes to the ecu and to the wiring harness head up the the gauge. Any help on finding the short or direction on where else to look would be appreciated.
Steve
Steve
