BeachRum1962
- Feb 23, 2011
- 17
Can someone tell me if the diagram on page 23 of this document http://lib.store.yahoo.net/lib/kingpumps/RUL-PMP-Standard-Bilge-pump-Manual.pdf is the way to have your bilge pump engage if the float switch is elevated but your battery switch is in the off position? I always thought my pump was wired directly to the battery, even though I have a 3 way switch. So, when I leave my boat in the water, I want to be protected but don't want to leave the battery switch on. I replaced the bilge pump yesterday but wired it the way it was and the pump doesn't engage unless the battery switch is on. I gather I will have to do some wire tracing but can someone explain the correct way to wire through a switch (which is set to auto) but does not require the battery switch on. Thanks.
