tswiczko
Master Chief Petty Officer
- Feb 15, 2009
- 838
2000 Silverado 4x4,5.3L vortec, automatic trans, electric shift transfercase
I replaced the carrier, ring gear, pinion, carrier bearings and pinion bearings about 17,000 miles ago and now it's making an awful racket.
I pulled the cover and the ring and pinion are intact as well as the spider gears. It makes this noise for a couple miles then stops... It literally stops making the noise. yes the fluid level is up to where it should be, there are no seal leaks, I pulled the drive shaft and have no play in the yolk, and no up down play in the axle shaft that I can feel.
Tire on
[url]http://www.facebook.com/video/video.php?v=2624886430333
[/URL]http://www.facebook.com/photo.php?v=2624830508935&set=vb.1500424835&type=2&permPage=1
Tire off
I'll be tearing into this over Thanksgiving break next week and I am looking for suggestions as to what this awful sound is that is coming from my truck or if any one out there has had a similar sound and what caused it
Thanks T
Tire on
Tire off
Thanks T
