shift linkage
mark adair
I've got a 50 hp Johnson. I had to replace the forward/reverse cable. I've full speed in foward, but it goes into reverse and I only have idle speed? Any help would be greatly appreciated! thanks
Chris1956
Re: shift linkage
You might tell us the year of the motor. I presume it is a single lever throttle?
If you remove the cowling, and push the throttle handle back as far as it will go, do you see the carbs open? Does the timing advance?
mark adair
Re: shift linkage
Its a 2002. you presumed correct. I will check your advice and let you know! Thanks
