obxleadlineman
- Oct 10, 2009
- 26
Hi E1, longtime reader, first time poster. Recently my 1985 70 Evinrude died on my way in. Acted like I ran her dry and she seized. Fired up after a momentary cooling and started to cruise again. Shut off after several minutes again, again refireing after brief cool down. refired and limped in.Fuel bulb firm, fuel still visible in filter. Next day I pull plugs and do a compression check and all is well, 110,+- a few lbs on each cylinder. Next I go thru the fuel lines, replacing 1 old cracked original hose. Ran better, still shut off at cruise, after warming, within 1 mile. Limp in. This time I replace the original power pack, coils, and plug wires. Go for a test,motor never ran smoother, same results. Now I check the stator, resistance is 1.5, book says 1.3+- 0.1, but that looks good enuff. Check rectifier, diodes are all working. So to summarize, originally happened after a day of fishing, now shuts off after 1 mile, every time. Gone thru fuel lines,new primer bulb, new power pack and coils, stator and rectifier test within specs. Don"t know what to do next, any suggestions would be much appreciated, Mark
