scrit9mm
- May 31, 2011
- 425
So, I am winterizing my boat today. I start by running the engine to warm up the oil (with muffs). I notice a small amount of water spraying up into the air by the movement of the belts. I begin inspecting to find where the water is coming from with no luck so I shut off the engine. There is water dripping from my circulating pump pulley. The pulley does have bow to stern play in it, approx 1/8". Could the play in the pulley mean there could be a leak there, or is that impossible. What is involved in replacing the circulating pump pulley? And, does this mean that my idea is correct that I need a whole new circulating pump assy? If so what is involved in replacing that?
