in to deep
- Nov 6, 2009
- 62
Disaster has struck my 3.0 L engine is cracked!!:facepalm: exhaust manifold too
1979 orion with a 181 cid 140hp omc whith a omc 400 out drive
what i have found is a older boat dont know the year but it is in the 80's it has a omc 3.8 L v6 cyl the block is shot cracked but is has a out drive for a v6 that has the 20 hole boot patter that is the same as on my boat!! the steering cable on my boat even hooks up to the bell houseing part of the out drive
he wants $750.00 fot the whole boat
then i find a boat with a Omc cobra ?? 4.3 L late 80's early 90's?? yes i asked for the years and all i got was well have to look at the paper work
any way it has a differant out drive setup then mine but he said the engine over heated when his wife and her friends took the boat out and now it has low compression on all cylinders and he wants $750.00 just for the engine
question will the out drive from the top boat bolt up too the 4.3 L engine????
i do not mind rebuilding the engine at this point but the above boat has all the tilt and trim parts still there so i think i can take the time too make it all work it is just will they mate up?? bellhouseing and fly wheel and all that??
option 2
i found a omc cobra 3.0 L engine it is a 1991 model at a salvage yard but it has no oil in the pan and when you pull the dirstick what oil does stick to it is a milky color but is has a fresh water cooling system on it and it is full of antifreeze!!! so what up with the milky color oil or lake of too??
he said he will sell the engine if it is ok and not cracked with a used manifold that is needed for my boat and out drive for $600.00
does this engine swap from a 1979 to a 1991 need any adapters???
Any ADVICE here please and help i know i dont have much to give you all year and models and what not but all parts are omc or omc cobra
yes my handle says it all I Am In To DEEP Bill
option 2
