Hello everyone,
I have a '71 Chrysler 85 hp that lost power on the last trip. Compression is #1=150, #2=150, #3=137 (psi). Have spark to all cylinders, fuel is new and correct mix, carbs seem to be working properly.
Additional problem is I had water in the lower unit after running for about 10 hours. Changed it to see if the seals would hold (hadn't been run in ten years), still pulled water into the lower unit oil. On the last trip after loss of power it started spitting oil sludge out of exhaust and overheating too quickly. I pulled the lower unit apart and found the inside is in near new condition (no rust, no shavings, no sign of wear). Before that I started and ran it on muffs and it idles, revs fine. Any ideas on what the deal is?
Thanks in advance.
Thanks in advance.
