15hp merc 4stroke stalls out/cuts off......
patnok
Runs fine then when i go to slow down it quits. or going along slow speed it will just cut out. wait a minute & starts up & away i go........ideas?
Ballymac
Re: 15hp merc 4stroke stalls out/cuts off......
Not sure what the year is but I'd start with the fuel supply - from tank to carbs. Eliminate as you go. Is idle set correctly? Is tank vented? clean & no water? fuel line restrictions? primer bukb staying hard, anti siphon good? any leaks, filter clean??? and work to the carbs - which may need a good cleaning. Idle jets might be restricted. Had the motor sat for a while?
patnok
clean tank,clean fresh gas with gas-shok, about 5 gals run through since i bought it. It is a intermittent problem. New gas line to motor,new filter under hood. Bulb does not stay "hard", what is the "anti siphon" thing you speak of? is a 2003 & yes it could have been setting a while. lots of no wake zones here so going at "slow speed minimum wake" it will just shut off. try to restart it runs very roughly, wait a minute (or less) & it starts up & goes as before.(everytime) Same speed slowing to idle it will shut off. SOMETIMES. Running on "plane" smooth & strong. slow down it quits EVERYTIME. Thermostat ok, waterpump "new" said the seller,strong pissing action out the bypass hose. damn thing runs/idles GREAT, until it doesn't..........I had a 1998 I never had this issue with, I know how good this little motor is.
patnok
Well I'm knockin' on wood here but today's speed trial went great! Full speed to idle , idle to full speed, about 4-5 miles stopping every 1/2 mile or so........must be the GAS-SHOK finely cleaned out the crud.....we'll see
patnok
patnok
again today it performed as expected:)
