Re: Will a 75 hp Johnson pull a wakeboarder or skier?
Good news, bad news....
What kind of skiing are you talking about? What kind of wake board ride are you after? Are you talking about kids or teens/adults (weight)? Skilled or beginners? Many variables....
The good news: a 14 ft boat with a 75 hp should freakin' fly! And, yes there's plenty to pull a BEGINNER skier, wake boarder or tuber. Depending on weight and skill level you may get two years out of this rig.
The bad news: although you can pull them, it doesn't mean the ride will be enjoyable for either the rider or those in the boat. As they grow with the sport, they will need serious, steady power. An experienced slalom skier will definitely stop this rig in its tracks, as they cut hard side to side, traveling perpendicular to the travel of the boat. They will feel it on the rope as they start to sink and you will feel it in the boat as it is momentarily stalled and you will feel the transom pulled side to side. They will stress the transom in a big way. A wake boarder may be able to do the same, again traveling perpendicular to the path of the boat. Eventually they will want to cut hard and jump wakes, creating intermittent loads on the stern. The better they get, the more power will be required.
A beginner slalom skier or a skier on two skies could get an enjoyable ride until they get bored and want to grow with the sport.
A tuber may get an easier ride as they are just pulled along for the ride, they will not, themselves, be adding load to the boat like cutting back and forth; totally different from skiing.
A serious slalom skier or wake boarder requires huge outboard power (140 or more) or an inboard.
If you are talking about youngsters just starting out, this is a good rig to learn on, but it will cost you later as they will need the power and steadiness, consistency, of an inboard.
Hope this helps.
J
p.s., welcome to the forum! You will get better advice if you go the water skiing section. We're the wrench-heads, not necessarily the ones on the end of the rope...
