IanFS
- Apr 21, 2009
- 188
Hi Guys
Mercruiser 4.3L Alpha 1 Gen 1
I've recently put new manifolds, elbows, exhaust flappers, Sterndrive seals, impeller, impller housing kit, etc onto my ageing Sea Ray.
When I started her for the first time, water flow was good, but one of the manifolds heated up quicker than the other which remained cool until I riggled the sprung loaded balls in the front of the thermostat housing (sorry not sure what they are called). After that the manifold cooling was ok.
What is puzzling me though is that before I replaced all the parts, when running with muffs, a light stream of cooling water would come out of the prop. Now there is nothing, only exhaust gases. I have the leg fully down, but there is no water coming out. The flow of water through the exhaust holes in the transom shield seems fine, the port side is stronger than the starboard side but still good flow on each side.
Is this because of a fault, or because there is more flow through the manifolds. Should there be a small stream of water exiting the prop?
Many thanks.
Many thanks.
