ledzeppelin135
- Jul 27, 2011
- 129
Ok so I got some new teleflex cables for my 83 merc 50hp. I Took apart the control box and i had to disconnect the idle throttle lever side off to change the wire on that side, the gear shift side I did not have to disconnect, I just slipped the pin that holds the cable out. I assembeled the box and ran the cables to the motor and took it out to the lake today. It seems to idle lower now and I only had to go so far with the throttle to get to full throttle and now I have to move the lever so far down that it is almost pointing at the ground to hit full throttle. Also, when I try reverse you can hear it almost getting into reverse, kind of like the gears starting to catch but if you try to go more it just starts to rev the motor really high. One last thing that I noticed is that the cables coming out of the motor are really uneven. The gear shift side comes out of the control box looking normal and the idle lever side is about an inch lower. This box seems so complex I do not even know where to begin and my manual does not really do anything for me. Please help! thanks!
