Hello all,<br />The above mentioned motor is mounted to my '85 Boston Whaler 22' Outrage Cuddy Cabin. I am lost and need a shop manual for this motor but haven't been able to find one. An intermittent problem which has gotten progressively worse over the last three years is driving me nuts! She runs fine for brief periods, then it's as though I have pulled the throttle back to half. Still sounds great...no miss, no sputter, just not full power. Then poof, right back to full throttle. I know this isn't much to go on, but it's a start, eh? There is one component I can't identify. It T's into the fuel line with a single hose just in front of the VRO, is bolted to the block, and has one ground wire and one wire attached to a tan wire which appears to go a sensor in the port head. My attention is on this "object" because it's about the only thing I haven't changed out yet. Any Ideas? Thanks in advance.
