I own a 1990 4.3 V6 Mercruiser and have been having some trouble with it.
I have owned the boat for 4 years and it has 550 hours on it
A few weeks back I noticed it would not rev up past 4,000rpms and I could not hit my top speed which is normally 42 or 43mph. I replaced all the spark plugs and took it out and it ran good for one 4 hour trip and then started doing the same thing again on the next trip. Even when I just have it in idle I can hear that something isn't right. My rmp gauge even jumps a little when its in idle.
Last time I took it out, the boat took off just fine on the first takeoff and I got up above 40 mph and rmps were at about 4500. After about 5 mins of running wide open it started to run weird again and went down to 37mph at about 3900rpms.
When running the engine wide open I can hear it trying to rev up and run like it should but something is definitely not quite right. Does this sound like a spark issue? Distributor issue?
Also when running it in idle I can hear a little ticking down near my spark plugs. I took the new plugs out to inspect them and they look fine.
Any help here is appreciated. Thanks
