I have a 1987 4.3 Cobra. The main ignition/engine connector shorted the 12 ga red/violet wire that runs to the ignition switch. This happened while the engine was running. The engine kept running fine but will not crank over after it was turned off. The wire cradle holding the connector wore through and grounded the 12 Ga red/violet wire as it enters the connector. According to the shop manual, there is a 20 amp fuse between the connector and the ignition switch on that circuit. I am sure it would be the first thing to go. I looked high and low and can't seem to locate it. Any ideas where it is located???
