Re: yamaha f100 rebuild carbs
Here is one idea. Make sure all your fuel lines are clean, filters are clean, drain them and then pump fresh gas from your fuel tank to your carbs with the fuel line disconnected at the carbs. Pump the gas into a jar and make sure it is clean.
Open up the drain screws in your carbs drain fuel, maybe spray a little carb cleaner into the drain. Connect up fuel line with the drains open pump some nice fresh fuel and see if it drains out. Install drain screws. now you should have fresh gas in your carbs.
Engine should fire right up. BE CAREFUL OF GAS AND GAS FUMES.
