Flywheel teeth gone -1985 90 hp Evinrude
njs458
Any thoughts on why 3 or 4 teeth in 3 different places are either worn down partially or completely? I have found a good replacement flywheel and do not want it to happen again.
Regards and thank you,
Jeff
Will Bark
Re: Flywheel teeth gone -1985 90 hp Evinrude
Could possibly be a misaligned starter or shims if used, are missing. Someone with better info or ideas will hopefully chime in. Good luck.
Faztbullet
If the flywheel teeth are damaged the bendix is too. Replace it also and check the upper bushing on the starter for excessive wear..
