I am doing a rebuild on my 1992 Cobra, 5.8L
I have removed every thing (strendrive, pivot and gimble hsngs) OK but can't get the cable out. Problem is the black plastic piece at the engine end of the cable - the inner core is pinched where it was held by the 2 set screws (now removed) and won't come out of the black piece.
I have tried to get the inner out from the sterndrive end by using a small tube against the outer and a nut on the threaded portion of the inner cable (like a puller), but it won't come out and I don't want to stretch the inner core.
The cable is in good condition and I want to re-use it so cutting is not an option. I need to get the black piece off so I can set the cable length (per posts regarding shifting problems; that is what started this whole exercise).
Any ideas on how to get that black bit off without destroying the cable or stretching the inner.
