should be fishin
- Nov 2, 2011
- 6
Bought the boat this summer Asked specifically if it idles and trolls well..... haha. Starts ok, idles ok, accelorates well, and criuses fine. but I like fishing. At idle, when you put it in gear, within 30 sec to 10 minutes the rpm starts to slow down and will stall, unless at this point you give it a quick shot with the primer. then it picks right back up and you're good for another 30 sec to 10 mins. makes for a long day on the lake.... I've cleaned the carbs perfectly, replaced the fuel pump, checked for fuel line leaks. All the linkages appear to be adjusted pretty close. Spark plugs are new. Tried a hotter set. The carbs are non adjustable (the are idle jets rather than mixture screws, which I've tried a larger set). The float bowls are full when running because it takes off great, without hesitation. Ran Sea Foam through. Tried octane booster. The only thing I thought made any difference was I raised the floats slightly. How big a difference does a good thermostat make in a 2 stroke outboard? The tell-tail warms up slightly after a mile or two of cruising, but isn't hot. What about the reed valves? I don't think there's any blow back through the carbs.... ANY advise?
