UNSUREBOATGUY
- Sep 14, 2009
- 117
I've got the assembly pulled out of the drive (gears look like new-I'm shocked and very pleased-its an '87) and have started disassembly. I have the setup sitting in the retainer nut wrench and stuck a screwdriver in the u-joints like it shows in the manual. I'm having a difficult time removing the 15/16" nut off of the yoke. I'm turning it counter clockwise-what gives? There is no corrosion or dirt or anything. I bent my screwdriver (granted, it is a fairly light duty one).
This is my first time attempting this repair and I just want to be sure I'm not doing something that might cause damage. Is it common for the nut to be this hard to remove? I figured this would be an easy part of the repair.
Thank you for your time and advice.
