Re: Winterizing
Well, you don't give the year BUT if you store the engine vertically, it is self draining. No anti-freeze is needed. You can fog the engine and drain the carb bowls, but that is really not necessary either.However, be aware that with alcohol containing gas, it is possible for water to collect in the bowls and corrode them to the point where they leak. So the choice to drain is yours. These engines are remarkably easy to store. If you have a dual exhaust or a Mercury lower unit--(mid 90s to late 90s) then be sure to cover the prop and lower unit so no rainwater or snowmelt will get in and freeze.
