Engine ID needed
dhoover54
new boat for someone not marine inclined. Trying to review the right service manual, but having trouble with motor ID.
metal tag on engine says: Mercury Marine, Model MCM 2.5Litre
separate metal tag on engine says: Transom Serial No. OC635646
back outside engine decal reads: Mercruiser Alpha One 3.0 Litre with separate metal tag on rear of boat: serial no OC635646
I've looked through the service manuals for ID but nothing can't see the obvious fit. Thank you for your patience and help. sorry I posted as private message to two members before I figured out how to do this here.
dave
Ballymac
Re: Engine ID needed
The engine serial number you're looking for should be on the starboard side of the engine, just above the starter. You should see a metal tag on the block. That's what you're looking for. Mercury has 3 serial numbers you'll need; engine, transom & drive. Good luck.
