gauge cluster problems
hoofing
I have a 1994 glastron and the gas gauge, trim gauge, temp gauge do not work properly they move around some but not like they should. the speedometer and tachometer work fine. i checked all the fuses and they all check out OK. i am a hvac service tech so i have some ele knowledge but very little dc experience or knowledge. can someone please shed some light on my problems. thanks
Slow Ride
Re: gauge cluster problems
Just get new guages! You can get all three of those for around $100.00 total! Save yourself the headache of trying to fix those old ones.
Ayuh,..... Test the Senders for those gauges...
NYBo
Welcome to iboats!:cool:
Since they are all acting strangely, look for what they have in common. That would be a common negative lead and a common positive lead that goes to the ignition switch. Check all the connections, especially the first in the chain.
