Re: Flywheel nut, 90 hp
Somebody may challenge this, and righfully so, but sticking a screwdriver between the flywheel gear and the starter works. I haven't bent a starter shaft yet.
A flywheel turner (automotive) or a strap wrench are the proper way to go. You can get it off with an impact wrench, but you need another method to tighten it with a torque wrench (required!!)
