135 blackmax doesnt run right
squirrelmaster
Hi, I just purchased a boat with a 1991 blackmax 135. The starter stuck on for the previous owner and fried some wiring and components. the main engine wiring harness, the starter solenoid, the mercury switch, and the rectifier have been replaced. the idle stabilizer has been removed. the engine will start and run very rough after a few starts to warm it up. it does not run consistently. any suggestions would be appreciated!
aussieflash
Re: 135 blackmax doesnt run right
Could be a thousand things.So start with checking spark on all cylinders,then check compression and inspect plug ends while doing compression.You will need a merc service manual.
Faztbullet
Check the basics first: Compression,Ignition and Fuel.
