theduckman
- Oct 13, 2011
- 20
Does anyone know how I can get ahold of a 1967 wards SeaKing 6 model #VWB27906A. The other question is how do you adjust the carb, there's a top screw and a screw on the side. I had it running with the throttle up a little so it wouldn't die, I turned the side screw and now it will idle but when I throttle up and let it down, (when it idles down) it dies??? what is the problem, also, where should the lean/middle/rich knob be? I'm not sure where it should be i've tried it different ways?
thanks
thanks
