Speakrdude
Ensign
- Feb 25, 2004
- 942
I deff. have a leak somewhere.
88 Merc. 5.7 MIE.
Fill up the HE with antifreeze, not there anymore!
No signs of water in the oil.
Been reworking this boat for a while. Engine has been sitting for a while. Have a stanton psi tester. Right off the bat, there is a leak in a copper joint at the cooler. I can pump it up and hear some leakage inside the engine somewhere.
My question is, will the long period of sitting cause a little leak? Should I fire it up for a bit, then test?
Just replaced the exhaust man block off with the good gray ones. (no more green ones.) Havent run it since then.
88 Merc. 5.7 MIE.
