66LazyDays43Footer
- Jun 29, 2011
- 2
1966 LazyDays Houseboat with twin Kiekhaufers and Mercruiser 1C sterndrives. Each have their own set of problems, but especially the housings are eat up with galvanic corrosion. Anodes are missing. One drive is hangin' at a funny angle, so the trim supports were replaced by the previous owner with a small piece of aluminum angle. Props are shots. Engines sound good and compression checks out, new points, plug, wires and fuel and they run fine, but know that very soon I will have a failure of one of these sterndrives. And here's the issue: No replacements have yet been located and very few parts can be located. Is there a possibility of replacing the entire drive unit? I do not mind patching and recutting the transom, afterall, this is an aluminum hull. I have considered removing the drives and mounting a couple 115 Yamahas on Moby mounts, but that is sounding a little too expensive, besides I cannot confirm if two outboards will have sufficient thrust to push 9 tons up river. What say the experts about either of these issues?
